Re: Timing a Farmall A
Posted by Jim Becker on October 27, 2012 at 16:38:59 from (173.74.120.222):
In Reply to: Timing a Farmall A posted by jamie Jackson on October 27, 2012 at 11:58:23:
Remove:
1) Slowly turn the engine until you hear a click from the magneto impulse drive.
2) Remove the distributor cap and make note of where the rotor is pointing.
3) Remove the magneto (without messing up the flange gasket).
-- do whatever needs to be done to the magneto --
-- don't turn the engine --
Install:
4) Rotate the magneto BACKWARDS until the rotor points where it did in step 2.
5) Bolt the magneto back in place, using the marks on the gasket to guide the exact position.
6) Recheck the timing per standard tune-up instructions. It will already be back where it was at the start.
An alternative to using the old gasket as a guide, you could put witness marks across the magneto flange to the block before step 3.
