Re: 1066 with 1466 engine
Posted by Wisconsin Cowman on October 27, 2012 at 16:59:47 from (97.95.49.225):
In Reply to: 1066 with 1466 engine posted by redjohn on October 27, 2012 at 16:13:00:
To me it sounds like you have the engine timing off 180 degrees. If there is fuel getting to the injectors then the pump is probably working. I would pull number 1 injector out and see if the piston is at or near TDC not that you have number 6 at TDC.
