Re: water in oil question
Posted by Janicholson on October 27, 2012 at 20:59:21 from (96.24.99.126):
In Reply to: water in oil question posted by M in NE on October 27, 2012 at 20:45:51:
With a good head, it must be either a cracked Cylinder bore allowing coolant to get between the sleeve and the bore, then dripping into the pan, or a rusted through core plug behind the front cover. There is no oil related connection to the water pump. There is no probable connection between the internal oil passage to the head and coolant.
Pull the oil pan and use a good light to see where it is dripping. from the base of a sleeve is worst case. because it could require a repair involving boring out the old block bore for a thick repair sleeve, then boring that out to fit a replacement sleeve. (common enough repair)
From the timing gear area is least painful, but requires removal of the front of the tractor to replace. Jim
