Re: Installing 4000 watt alternator on SH
Posted by Wardner on October 27, 2012 at 23:20:39 from (4.154.228.13):
In Reply to: Installing 4000 watt alternator on SH posted by Va Gasman on October 27, 2012 at 20:33:20:
If running off the belt pulley gear box, get a two groove blank v-belt pulley available from McMaster-Carr or similar. Put it in a lathe and machine a face that will mount to the pulley flange on the tractor. I think the gear box runs at around 1000 rpm. You will have to calculate the v-belt pulley diameter based on design speed of the alternator and desired engine rpm.
Tuck the alternator under the gas tank. I believe alternators can run in either direction but the fan is probably formed for clockwise when viewed from the front. Other fans may be available from marine, aviation, or industrial vendors. You will need to fabricate a swing mount to tighten the v-belts.
Generator below turns at 3600 rpm at no load engine speed in order to get 60 cycles per second. It is 12,000 watts running at 240 VAC. I had the correct sized pulley but it was attached to an air compressor so I added that too..
third party image
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
