Re: Super-A hydraulic Problem
Posted by Gary730 on October 28, 2012 at 06:20:45 from (98.70.222.68):
In Reply to: Super-A hydraulic Problem posted by Gary730 on October 22, 2012 at 13:44:27:
Eureka! It is fixed. I put it together for the 7th time, and now it works. Apparently the relief ball end of the unload piston had a odd shaped wear pattern due to 60 plus years of wear and tear. Apparently when re-installing the unload piston, it was never back in the original position. When unload pressure was applied to the unload piston it would cock in its bore when making contact with the unload ball. Dressing up the ball end of the unload piston cured the problem.
