First thing I'd do is check the ignition timing. Also the verify the centrifugal advance is working. (Timing at idle can be right on, but if the centrifugal is stuck timing can be off by 30 deg or more at governed RPM. This will rob a LOT of power.)
Next check the carb power mixture. If the carb has a high speed mixture screws turn it OUT 1/2 turn at a time and see if this helps. Or if the carb has a fixed high speed mixture, try gradually pulling the choke while under load. If you get a bit more power with the choke slightly closed, the carb needs attention.
Finally check/adjust the valve lash with the engine warm.
If none the above gives no improvement there's a more serious problem going on (low compression, etc).
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
