Posted by Janicholson on October 28, 2012 at 13:03:58 from (96.24.99.126):
In Reply to: B front seal posted by andy in de. on October 28, 2012 at 12:51:42:
Yes. It is more complex, as the front cover is also removed to access the seal. A hydraulic puller,(or very stout screw puller and bearing splitter is needed to pull the front pulley (could have a setscrew, but is pressed on) See the archives for puller designs that work. Those that don't break the pulley! Speedy sleeve, or setting the new seal to run on unworn shaft is a necessary ingredient. a cover gasket is also needed. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
