Re: Timing a Farmall A
Posted by PretendFarmer on October 29, 2012 at 07:03:58 from (66.87.124.154):
In Reply to: Timing a Farmall A posted by jamie Jackson on October 27, 2012 at 11:58:23:
I have the manual.
For the install;
1. Rotate engine to top dead center on compression stroke #1 cylinder.
2. There is a small view hole in the bottom of the bell housing. You should see "d/c 1/4". This wording can be difficult to see and it is small.
3. If you succeeded in step 2, turn the mag so that your rotor points to # 1 and bolt it up properly lining up the key way.
That's it. Any other method could yield problems.
