Re: OT book International Harvester Internal Combustion Engi
Posted by Hendrik on October 29, 2012 at 08:00:42 from (194.53.253.51):
In Reply to: Re: OT book International Harvester Internal Combustion Engi posted by rustyfarmall on October 29, 2012 at 07:30:10:
Hello Rusty.
In the ad the item location is indicated as: "Hillsdale, NY, United States".
So, don't worry; you will be buying a US product.
Confusion may have arisen because I am located in The Netherlands. (Which means that I am 6 to 9 degrees, er, hours out of time with you ;-)
Best, Hendrik
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
