IH 240 rear whee hub question
Posted by mfb_stringridge on October 29, 2012 at 09:52:54 from (12.2.115.11):
I have a 1960 240 utility. I have noticed that it has a leak coming from the rear axle, where the 4 bolt cover is, but looks like its coming from the seal, not in between the cover and housing. I have removed the wheel and here is the question: How do I remove the hub that the wheel actually bolts on to? it looks like its just splined onto the shaft, and I saw a snap ring at the end of the shaft under a cover held on by a single bolt, but it looks like all that snap ring does is locates where the hub is seated. Is that hub pressed onto the shaft? if so, do i need a puller to get it off, because i dont want to start beating and tear something up. thanks for any info. God Bless America.
