Posted by rustred on October 29, 2012 at 19:53:33 from (72.172.100.113):
In Reply to: F20 mag rod posted by Daninsc on October 29, 2012 at 19:21:23:
the rod operates the cap on the points by advancing or retarding spark. in the up position is for engine stop which grounds out the spark. if in this position it will not start. to start engine i usually place lever in centre position then once running can move lever to the end or down position on mag. just operate it from mag. and see if you have spark while cranking. also check your points for gap @ .013 on high point of lobe. also make sure contacts are clean. to check gap just crank engine very very slow till you hear impulse trip and stop right there. that is the high side of cam lobe.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
