Re: tractor keeps running after its shut off
Posted by old on October 29, 2012 at 21:35:40 from (209.86.226.34):
In Reply to: tractor keeps running after its shut off posted by Kurt LaGrander on October 29, 2012 at 20:40:33:
Running as in what is called dieseling or running as in true engine running?? If dieseling that is caused by hot spots in the engine which in turn is burning the fuel that is still being sucked into the engine from the carb. It is caused by carbon build up in the cylinder on the valves and the top of the pistons. On some it helps to pour a qt if ATF into 3-5 gal of gas and run it that way to clean out the carbon
