When we had a tractor that developed this problem, (AC D15) we just turned off the ignition with it in gear, let the momentum take it to a stop. In the barn hanging tobacco we would get in place and let the clutch out when we shut it down.
The 140 at one time developed a backfeed thru the alternator, turned it off, the engine would restart. With the key off, 6-8 volts was backfeeding to the coil. unplugging the white connector on the alternator solved this before turning the switch off.
What it would do is cut off, and before the engine stopped turning the current from the alt would fire a spark plug, which would turn the alt, firing more spark plugs. We figured it was getting the 6 volts from somewhere, removing the neg battery cable had no effect, unplugging the alt did.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
