Re: tractor keeps running after its shut off
Posted by rustred on October 30, 2012 at 07:27:40 from (72.172.100.113):
In Reply to: tractor keeps running after its shut off posted by Kurt LaGrander on October 29, 2012 at 20:40:33:
the best cure for run-on is to adjust the idle screw so engine actually stops when throttle is at slowest idle position. this puts the throttle plate in the fully closed position and it can not run.might not get tractor to completly stop with the screw backed right out though, but it sure helps the problem if yu can get the idle slowed right down.
GM cured this problem with an electric solenoid so that when key is turned of the solenoid is deactivated and closes throttle plates completely.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
