Re: Farmall M 3 Point Backhoe
Posted by glennster on October 30, 2012 at 19:03:49 from (99.90.9.201):
In Reply to: Farmall M 3 Point Backhoe posted by Sparky2 on October 30, 2012 at 17:21:36:
i would guess the m could carry the hoe. they can handle a mounted corn picker or cotton picker conversion, prolly pretty close weight wise. for hydraulics to run the hoe, you want a pto driven pump. the belly pump is just too slow. you will need some weight in the front of the tractor too, as it will be way light going down the road, and make for some real pucker factor wheelies. maybe add a loader to the front of the m for some extra weight and a little more usefulness. you will need a pretty good size hydraulic oil resevoir too, so you dont dont over heat it.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
