Re: Mccormick Deering o4 oil pressure problems
Posted by Janicholson on October 30, 2012 at 19:57:33 from (96.24.99.126):
In Reply to: Mccormick Deering o4 oil pressure problems posted by Pavel Ammon on October 30, 2012 at 18:54:09:
If the engine gauge is showing oil pressure, it is probably getting oil to the lower end. The oil is routed to the head from the center cam bearing through a drilled hole to the head. The cam bearing has two oil holes in it that align with a drilling in the cam for a moment as the cam turns. This spurt of oil is all that is needed to lube the top end. If the cam bearing is installed correctly, the oil passage might be plugged. a gas welding rod, or straight coat hanger wire could be inserted into the hole from the top while the engine is slowly rotated by hand. If the cam bearing holes are aligned correctly, the wire should eventually drop into the cam passage. (do not keep turning, as the cam will chop off the wire, resulting an a dissassembly to remove the piece!!!) I hope this helps. Jim
