Re: Re: Re: Replacing fan belt on H
Posted by Haas on October 21, 2000 at 06:20:44 from (129.37.117.67):
In Reply to: Re: Re: Replacing fan belt on H posted by John C on October 21, 2000 at 05:14:00:
The set screw that holds the flange from turning also has a lock nut on it that has to be loose before you can loosen the set screw. The set screw has a screwdriver slot. I believe the lock nut takes a 1/2 inch wrench. If the thing has not been loose for a while, you will need to clean the grease and dirt off the fan hub and threads.
Post A Followup
: Re: Re: Re: Re: Replacing fan belt on H
