300 TA operation
Posted by Zachary Hoyt on October 31, 2012 at 19:03:51 from (184.12.70.70):
I am wondering if I have the TA on my 300 adjusted correctly and if I am using it properly. I adjusted it following the step by step procedure in my I&T manual. In high I am able to shift up through gears just as I would with my H but when I stop and go to shift into reverse the shifter will often not move until I pull the TA lever back, especially if I the tractor is pointing uphill. I think I read somewhere that the sprague clutch is supposed to keep the tractor from rolling back when I step on the clutch pedal, but is it also supposed to not let the shift lever move? Any advice will be much appreciated. I do know to move the TA rapidly between low and high, I have heard that said many times on this site.
Zach
