Not sure what your book says, but I did mine according to the book I have.
#1. take out the plug on #1 and turn engine over(with hand crank) until top dead center on compression stroke. Compression stroke is obvious when you put your thumb over the spark plug hole you will feel the pressure push your thumb off. I'm sure you already knew that.
#2. Look under the bell housing. There is a small round hole up at the front, again on the bottom. Find the mark on the flywheel that reads "D-c 1/4". When that mark is in the center of the window, you can continue to step #3. Keep in mind that the mark is small and difficult to read.
#3. Turn mag by hand until the rotor is pointing at #1 cylinder. Click it over and then turn it to align with the key slot properly, bolt it up. good to go.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
