Re: six volt starter
Posted by mkirsch on November 01, 2012 at 07:06:07 from (64.80.110.74):
In Reply to: six volt starter posted by red theo on October 31, 2012 at 17:12:52:
As a general rule, if an M isn't running after 30 seconds of cranking, it's not going to run. You need to stop, assess the situation, make adjustments, and try again.
How well was it cranking over before? Your problem right along here may very well be bad battery cable connections.
These tractors didn't turn over real fast on 6V from the get-go, but if all you were getting is an "rrrrrrrrrrrrr-WOW-rrrrrrrrrrrrrrr-WOW," then you've found your whole problem.
It should sound more like, "WOW, WOW, WOW, WOW, WOW."
