Since you have done it before with no problem, I imagine you are doing the procedure just fine. I suspect the governor gear was not timed properly when it was installed. With the magneto removed, set the engine at TDC and look at the notches the drive lugs of the magneto engage in. They should be at 35 degrees off horizontal, in the 2 - 8 o'clock position. If the drive is off, the governor isn't timed. If the drive is correct, you may have a problem in the magneto: misassembly or the wrong impulse unit installed.
TDC on an A is marked on the flywheel and harder to see than on the front pulley of a Cub.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
