Re: Farmall A and B magnito install
Posted by El Toro on November 01, 2012 at 10:01:27 from (108.3.143.30):
In Reply to: Farmall A and B magnito install posted by dtaylor on October 31, 2012 at 22:31:27:
When you pull a mag or a distributor doesn't matter if it's a 4 cylinder or 8 cylinder gas engines note where the rotor is pointing and either make a sketch or use a magic marker and make a mark inside the housing. THEN DON"T MOVE THE ENGINE while the mag or distributor is off. When you're ready to to install just rotate the rotor to the mark in the housing or by your sketch and reinstall the mag or distributor. Hal
