Posted by El Toro on November 01, 2012 at 10:23:49 from (108.3.143.30):
In Reply to: 1951 M crank? posted by DC3puller on November 01, 2012 at 09:28:59:
That measurement you posted is for the H model Farmall. Prior to S/N 278050 your main journal should measure 2.7474"-2.7485" after that S/N they should measure 2.8075"-2.8085" for the Farmall M's. Look in your manual. Have your machine shop to measure your crankshaft. The measurement you posted shows .252" of wear or machining. Make sure you 're working on a Farmall M. If have an H Farmall your shaft isn't worn. I would have it polished and buy your bearings from that machine shop. They will also measure the rod journals. They won't grind it undersize unless it needs it. You need to make sure you have a Farmall M. Hal
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
