Re: farmall sloppy shifter fix
Posted by Haas on November 01, 2012 at 16:17:52 from (50.142.111.41):
In Reply to: Re: farmall sloppy shifter fix posted by hoof print on November 01, 2012 at 13:08:49:
I put one of the sloppy shifter fixes in my I-6 last year. It made a world of difference!! And it's not just the worn end of the shifter that causes the problem. On mine, the pin that goes through the shifter was supposed to be 7/16 inch diameter. It was worn to less than 3/8 inch, plus the hole in the tower on the cover plate was wallowed out. The sloppy shifter fix took care of all those problems. I could not see much wear on the end of the shifter, possibly it had been repaired previously.
