Re: 350 throttle problem
Posted by The tractor vet on November 01, 2012 at 16:52:33 from (75.24.0.62):
In Reply to: Re: 350 throttle problem posted by rustyfarmall on November 01, 2012 at 15:00:55:
You can use bearing bronze or a harder steel and PRESS them in with .0015-0025 interference fit , Drill the hole a little bigger then the dia. of the spring wire then champer both side so that the spring is riding on about half the total thickness of the bushing and also allows for ease of getting the spring in the holes . Doing this cures idling down problems and also make the gov. work like it should .
