Re: 706 Gas Tractor Quit
Posted by LOU from Wi. on November 01, 2012 at 23:45:36 from (72.160.225.99):
In Reply to: 706 Gas Tractor Quit posted by Tobaccoman on November 01, 2012 at 18:25:35:
On our 706 gas, we had a problem with fuel delivery, we had to take carb apart twice, but finally found it. There was a blockage in the carb( not sure what the name is) but there is a small tube inside the carb with 3-4 different little orfices drilled thru the sides and they were plugged with dirt and gunk.Cleaned them out with a torch kit cleaner replaced the gasket on the carb bottom,it started and ran fine after that. Hope it helps.
LOU
