Re: Adding 2 way hydraulics to super M
Posted by jim warehime on November 02, 2012 at 03:12:42 from (174.255.36.146):
In Reply to: Adding 2 way hydraulics to super M posted by Fullers Farmalls on November 02, 2012 at 00:43:02:
That's correct, on your super m the pressue line from pump would goto the inport on the 2way valve then be diverted to the cylinder ports. There would also be a return line from the valve to the res. The same concept was used with the belly pump om the m. Ill try and get some pics of the 2way set up on my md ( ih 2way set up) and that should give you something to go by. Would be same principle regaurdless of being ih valve or aftermarket. Jim.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
