Re: Adding 2 way hydraulics to super M
Posted by D Slater on November 02, 2012 at 06:30:04 from (184.15.42.25):
In Reply to: Adding 2 way hydraulics to super M posted by Fullers Farmalls on November 02, 2012 at 00:43:02:
Thinking maybe you want to get pressure from one of the pressure ports and then mount a control valve for double acting cylinders where handy. Run hose from pressure port to valve inlet. Return line from valve to drain plug on the transmission driven liftall. Put a tee in so it can still be drained. If its live hydraulic with the unit under the tank its the same hookup but the return line goes to the fill opening but that leads to trouble sometimes. A tee installed in the pump suction line works with the return hose going in the tee. Other openings on the valve are plumbed to the cylinders. Needs to be a open center valve. Also the liftall unit rod need to be locked in the pump position when using the add on valve. Relief valve in the liftall unit will still work to control the pressure.
If thats not the way you were meaning let me know.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
