Re: Adding 2 way hydraulics to super M
Posted by mkirsch on November 02, 2012 at 07:23:49 from (67.253.161.186):
In Reply to: Adding 2 way hydraulics to super M posted by Fullers Farmalls on November 02, 2012 at 00:43:02:
Pick up a double-acting OPEN CENTER control valve. One with NPT type fittings is easiest to deal with.
Mount the valve in a convenient location.
Run a hose from one of the belly pump pressure ports to the IN on the new valve. Plug the other two ports on the belly pump.
Run a hose from the OUT on the new valve to the belly reservoir fill pipe under the gas tank.
Run hoses from the WORK (sometimes A & B) ports to the rear of the tractor. Add couplers, and you're done!
