Re: Valve lube on old McC-D tractors
Posted by Old-F20 on November 02, 2012 at 19:49:27 from (71.7.101.5):
In Reply to: Valve lube on old McC-D tractors posted by 36F30 on November 02, 2012 at 17:29:07:
pretty much sums it up. if you constanly lube the valvetrain with oil from the crankcase your gonna run out and you can guess what will happen.
i plow alot with one of my W-30's and i dont find it difficult to manually oil the vavle tray once a day with a squirt can :wink:
