The head is probably not the issue. The compression is good, so head work will not give results. First would be oil. I would put synthetic 15W-40 oil in it. The synthetic is more stable at temperature, It is also probably thicker at operating temps, and thinner at cold start than 30 wt. If that 40.00 change does not assist this worn engine, Sleeves, pistons and rings (about 750 if you do it) will make it operate well, and have the advantage of higher compression pistons, and bigger bore. Changing the head to a higher compression Gasoline head would also add hp. jIM
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
