Re: M is getting hot
Posted by rustred on November 03, 2012 at 12:12:06 from (72.172.100.113):
In Reply to: M is getting hot posted by BigTone on November 03, 2012 at 11:54:54:
appears like you have an air lock. happens when you have thermostate installed. also dont idle slow at 400 rpm. idle at 800-900 rpm so you have circ. and air flow. have you kept track how much coolant you put in in rad. possibly not full till thermosat opens. temp will go up then drop back down when thermostat opens.
also helps to cover rad till temp is up.
