Re: M is getting hot
Posted by Janicholson on November 03, 2012 at 14:14:18 from (96.24.99.126):
In Reply to: Re: M is getting hot posted by BigTone on November 03, 2012 at 13:27:34:
The temp gauge may be inaccurate. Checking it is pretty easy. Remove the sending bulb (plug the hole with a stopper or cork to keep from drailing the Coolant) put it in a small container (tin can will do) and fill with water to cover the bulb. put a candy thermometer (or other thermometer that can handle 250 degrees) Heat the can with a propane torch and compare the temps displayed. If it is pretty accurate, the water will simmer at around 205 and boil at 212. (sea level) less if at elevation. Thermostat should be placed with the spring (capsule) end toward the engine.
If there are bubbles in the coolant all the time it is running, you may have a head gasket issue.
Or a cracked head(nooooo) but lets go for easy things first. Jim
