Re: Belly pump on a Farmall
Posted by Janicholson on November 03, 2012 at 15:04:31 from (96.24.99.126):
In Reply to: Belly pump on a Farmall posted by I don't know on November 03, 2012 at 14:41:57:
It is turning when ever the clutch is engaged (foot off pedal) this causes no problem for operation because it is open center hydraulics. Output goes to input with no restriction. It can be (and normally is operated with the lever/rod hooked on the rod stop at the hold position. (also no load on the system). If you feel the pump is slowing the engine when the rod is in that position (middle of rod stroke) then possibly the rod lever is not in its correct position on the pump valve. Less likely. Jim
