Posted by mkirsch on November 03, 2012 at 19:33:34 from (67.253.161.186):
In Reply to: Belly pump on a Farmall posted by I don't know on November 03, 2012 at 14:41:57:
What about it running are you concerned about?
It should not be making a squealing noise all the time, for sure. That indicates its under pressure and the internal valve is not releasing for some reason.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
