Posted by David G on November 04, 2012 at 07:45:32 from (205.215.206.18):
In Reply to: antifreeze or water posted by ih54 on November 04, 2012 at 04:14:10:
HP change is negligable between glycol/water. The racers use water because they dump out the hot water between races and do not encounter freezing conditions.
A 50/50 mix is the best compromise between cooling, corrosion prevention and freezing prevention. The pressure cap does more for boiling prevention then the glycol.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
