Re: Rust stuck M farmall
Posted by El Toro on November 04, 2012 at 13:22:48 from (108.3.143.30):
In Reply to: Rust stuck M farmall posted by Ronald Jeter on November 04, 2012 at 12:45:39:
Pull the head and oil pan. Remove anything flammable. Pour kerosene on top of one piston and set it on fire. Have the rod cap off that piston. Make sure you're not near any building.
Use a big hammer and a piece of 2 X 2 oak then see if the piston can be driven out. You may need to heat it again. Hal
