Re: antifreeze or water
Posted by David G on November 04, 2012 at 18:13:20 from (205.215.206.18):
In Reply to: antifreeze or water posted by ih54 on November 04, 2012 at 04:14:10:
I did check the viscosity numbers, 50/50 mix has a viscosity of around 20 at freezing, and goes down to 2 at 200 degrees. Water has viscosity of about 1 within those ranges.
A thicker liquid will take more HP, but the differences in viscosity is negligible at operating temperatures.
