Re: farmall oiling
Posted by rhtx55 on November 05, 2012 at 17:17:16 from (68.185.207.25):
In Reply to: farmall oiling posted by williamscarfan on November 04, 2012 at 12:18:53:
Double check to see that you have the correct oil filter first.
If not,
Sounds like the oil may be dropping below the oil pump pick up for some reason.
That or the by-pass releif valve spring is sprung, spring not stout enough to hold up when it gets warm.
Double check the oil level, I would simply change the oil & filter to be sure of the viscosity & amount first & go from there.
How long has it had this warm oil pressure symptom?
Has it gradually become worse, or was it sudden?
