Air cleaner
Posted by Farmall 450 lp on November 05, 2012 at 18:59:40 from (70.199.192.91):
So today i was bored and i thought it would be a good time to take the valve cover off and check the torque on the head after a rebuild with around 10 hours run time on it. Then to my surprise there was a thin layer of dirt on the head. The only way i thought it could have gotten in was through the valve cover breather. Yet the hose that runs to the valve cover is hooked up and it seemed like all filters were in place. So getting down to the point, on the cover that fits on top of the aircleaner (not the jar kind and almost looks like a mushroom) is there supposed to be a filter/foam in it? Because mine doesnt have one. Also is the valve cover breather tube supposed to be located 5 to 7 inches down from the top of the aircleaner because in that location it has no filtration for the air. If there is supposed to be a filter in the mushroom shaped aircleaner top, what should i use as one?I almost had a cow when i saw dirt under the valve cover and would really appreciate any suggestions or help. Thanks.
