Re: Is this how the thermostat fits? PICS
Posted by pete 23 on November 06, 2012 at 11:48:03 from (74.32.238.2):
In Reply to: Is this how the thermostat fits? PICS posted by BigTone on November 06, 2012 at 10:04:35:
You had it in correct, as you can see it will not
go the other way. If that tube fits into it's hole
in upper housing freely it will more than likely
leak around it and definetely not stick.
Here is what I would do now that you have it off,
is take fan belt off so water pump won't turn,
fill as much coolant as you can get in right at
the engine. Start engine and coolant should not
move. If it rises up you have a combustion leak
causing heating problem. You have to do this
quickly as it will start to rise as soon as it
warms so you have less than maybe a minute to take
a look.
