Re: Janicholson or anyone else, what to try next?
Posted by TractormanNC on November 06, 2012 at 12:28:35 from (108.72.58.200):
In Reply to: Janicholson or anyone else, what to try next? posted by BigTone on November 06, 2012 at 12:14:00:
If your water pump looks like the one in the picture, you have found your problem. the water pump is NOT turning. Two of the 4 bolts in the front of the pulley need to be replaced by studs which go through the two vacant holes in the front cross piece (the driver). two springs go between the hex on the studs and the back side of the driver. The driver must be removed to put the springs on.
