Posted by The tractor vet on November 06, 2012 at 14:42:16 from (75.24.0.62):
In Reply to: 966 clutch PTO posted by CRAIGREAVLEY on November 06, 2012 at 09:56:21:
It all depends on how deep ya want to go into it . IF you want to replace the clutch pack then the only thing ya need is the fitting to go into the test port and a good hyd . pressure gauge to check and reset if needed and a cherry picker to help ya remove and install . If you want to go deeper then ya need a spring compressor to compress the spring to get the clutch drum off to get back into the brakes and seals. , and you will need a piston ring compressor to compress the new teflon seals when you install them . a seal driver helps when installing the seals.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
