Re: Janicholson or anyone else, what to try next?
Posted by S2710 on November 06, 2012 at 15:36:21 from (98.143.227.89):
In Reply to: Re: Janicholson or anyone else, what to try next? posted by BigTone on November 06, 2012 at 13:49:48:
If you don't have the right ones you can use bolts and cut the head off and use a nut to tighten it down and go to your hardware store and get a two spring to hold the impeller in place. HTH
Bob
