Re: Speed Plowing.
Posted by gene bender on November 06, 2012 at 15:48:32 from (207.177.56.85):
In Reply to: Speed Plowing. posted by High Octane on November 06, 2012 at 13:17:12:
The problem is the style of the bottom on the plow as some will just throw the dirt unless you dont care.Add on cover boards could help but you got to remember those old bottoms werent made for speed. I did plow onetime fall planted rye grass in the spring things were just rite had M with 3-14 and used 2-od Heisler 1/2 throttle could throw dirt pretty good at full throttle running 8in deep in good black ground.
