Re: All SMD experts - what is noise?
Posted by Janicholson on November 06, 2012 at 17:59:22 from (96.24.99.126):
In Reply to: All SMD experts - what is noise? posted by Dan MD on November 06, 2012 at 16:09:08:
Is the muffler at all loose on the stack. if it can be wiggled, clamp it to see if there is noise there.
If you believe there is a pretty consistent misfire, use a laser pointed heat sensor on the exhaust ports to see if you can folow the misfire.
if it shows up as a cooler stack, change injectors from hole to hole to see if it follows the injector. Poor injector patterning can cause that sound. Jim
