Re: Lift All
Posted by john *.?-!.* cub owner on November 06, 2012 at 19:57:26 from (75.120.53.106):
In Reply to: Lift All posted by pete 23 on November 01, 2012 at 08:25:03:
Quoting Removed, click Modern View to seeThere is a spring inside that originally pulled the lever back down to the hold position when it reached full pressure. It may have broken and gone through the pump. On on ours did that. Did not shear shaft, but took chunks out of pump and locked both the pump and tranny spindles on so tight I have not been able to get them off.
