Re: M Serial # Suffix Questions for D Slater or Others
Posted by Bob M on November 07, 2012 at 08:58:15 from (69.207.86.27):
In Reply to: M Serial # Suffix Questions for D Slater or Others posted by Tobaccoman on November 07, 2012 at 07:36:37:
Means the transmission has both slower 1st AND faster ("7 mph") 4th gears.
However transmission ratios for gears 2, 3, and 5 are unchanged. So also I believe is reverse.
