Re: Mc cormick deering 10-20 parts
Posted by Nebraska Kirk on November 07, 2012 at 19:33:58 from (207.91.4.159):
In Reply to: Mc cormick deering 10-20 parts posted by 1468 Chris on November 07, 2012 at 16:29:29:
Yes, you can get a brass float, but you have to solder it to your existing float arm. Not a big deal if you have soldering tools. The new cork floats are coated to resist the modern gas. I have had no trouble with them. But the brass float from one source is actually cheaper than the cork.
Here are the two main sources for new 10-20 parts.
www.riceequipmentinc.com
www.thefordsonhouse.com
