Posted by Janicholson on November 07, 2012 at 20:06:29 from (96.24.99.126):
In Reply to: Farmall 300 Carb posted by Sparky2 on November 07, 2012 at 19:47:49:
Bottom screw front Load mixture adjustment 3 to 4 turns out from light seating. idle screw (left top about 1/3 to 1/2 way in (not critical at startup) idle mixture screw 3 turns out (or so) After start, the idle mixture screw is adjusted for best speed then speed for 500rpm or so, then idle mix again, then speed. Power mixture should be set so (if warm) it goes from idle to full throttle in neutral without stumbling, and with very minimal black smoke or none. when pulling loads, it might be 1/2 to one turn out from there to allow full power. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
